CAPS Configuration Methods
Beginning with Simphony version 2.9, you can run the CAPS web application on Microsoft Internet Information Services (IIS) and also have the CAPS database reside on an Oracle database.
Running CAPS as a web service is an alternative method to running CAPS as a Windows service and a workstation-based service. In Simphony versions earlier than 2.9, CAPS runs only on a Microsoft SQL Server database and the embedded Simphony Service Host Webkit web server.
CAPS needs to be on-property regardless of which configuration fits the business architecture. CAPS holds state information of checks and hence, the CAPS service must be on sticky sessions. The CAPS service cannot reside behind a load balancer.
You can run CAPS using one of the following types of configuration methods:
  • CAPS Running on a POS Client Workstation (along with the POS client)
  • CAPS Running on a POS Client Workstation (without the POS client)
  • CAPS Running as a Windows Service with Oracle database
  • CAPS Running as a Windows Service with Microsoft SQL Server database
  • CAPS Running as a Web Service on Microsoft Internet Information Services (IIS) with Oracle database
  • CAPS Running as a Web Service on Microsoft IIS with Microsoft SQL Server database
When CAPS on Microsoft IIS is configured, this is the only service assigned to the Service Host on which CAPS on Microsoft IIS is configured to run. Do not configure other services (for example, Interface, KDS Controller, and so on) to run on this Service Host.
Table 31-1 CAPS Configuration Methods
CAPS Configuration Details CAPS on a POS Client Workstation CAPS as a Windows Service CAPS as a Web Service on Microsoft IIS
CAPS Database
Microsoft SQL Express
Oracle Database
Oracle Database
CAPS Service Host
POS client
CAPS Only
CAPS Only
Hardware
All supported Oracle MICROS workstations
All supported Microsoft Windows Servers
