Discounts With Condiments
You can apply manual, automatic, and coupon discounts to a check when a condiment item is present on the check. A workstation operator can manually apply a discount by selecting the condiment item. For example, configure a bagel to be a parent menu item and configure the condiment, such as cream cheese, to trigger a 5% discount. As a result, when the workstation operator enters the customer order for a bagel with cream cheese, the system applies the discount after the workstation operator selects cream cheese.
Place condiments in trigger menu item groups to have Simphony apply automatic and coupon discounts.
Specify the condiment to be the trigger
Set the discount to apply to the parent menu item, condiment, or both
Set up the discount for a condiment
Create a discount button to appear on the workstation page
