Configuring a Till Through Extensibility
ECM provides the Designate till number during assignment capability through extensibility. When you set the InitiatingCommand.Arguments to a valid receptacle object number, the application attempts to use that till when assigning a till to a workstation. If the till is not found or is assigned to another workstation, the application prompts the workstation operator for the till to assign.
Related Topics
Parent topic: Enterprise Cash Management
