Device Information
The Device Information tab displays unsupported component details. For example, the tab identifies workstation operating systems and databases that are no longer supported. Use the information on the tab to prepare your locations to upgrade to the same version of Simphony on which your enterprise is running. To access the Device Information tab in the EMC, select the Enterprise level, click Tasks, and then click Device Information.
