Barcode Reader
A barcode is an optical machine-readable representation of data. Barcodes are used to quickly order items. Workstation operators scan barcodes using barcode scanners attached to workstations. When a barcode is scanned, the workstation software processes the data and matches it with a menu item configured in the Simphony database.
The Barcodes module in the EMC lets you configure barcode menu
item ordering. The Barcodes module allows you to:
Associate many different barcodes with the same menu item (for example, pricing chewing gum items the same).
Associate two different prices of one definition with different barcodes (for example, small or large coffee).
Use a maximum of 14-digit barcode.
