Touchscreen Page Table Management Tasks
Oracle Hospitality recommends that you create table management forms on a page for the enhanced dining table functions. You can use the templates provided in Simphony. If the property uses future reservations or multiple dining room layouts, a Tabbed Template provides workstation operators with a smoother means to navigate between wait lists, reservation lists, and table layouts.
The Table Management System (TMS), Wait List, and Reservation functions must reside within the same content area on a page in order to interact.
Setting the Host Command Area
Setting the Dining Table Status
Setting Employee Lines
Creating a Section Layout
Creating a button for the Employee Section Assignment Report
Creating Enhanced Dining Tables
Setting Table Management Functions in the Guest Check Detail Area
