Table Management, Reservation, and Wait List Configuration Prerequisites
Configure the Simphony Table Management System (TMS)
Configure the Simphony Wait List to accept and seat guests with reservations
If the property is using a Wait List, but does not take reservations, you only need to configure the TMS before setting up the Wait List. (A Reservation List is not required with the Wait List.)
The Simphony TMS, Reservations, and Wait List integrate with loyalty applications such as Oracle Hospitality Gift and Loyalty, and third party loyalty applications based on the loadable loyalty modules. When you use Simphony TMS, Reservations, or Wait List with loyalty applications, workstation operators can associate the loyalty account with the reservation request or walk-in guest. After associating guest loyalty information with the table request, the information follows the guest through the life of the guest check. To use the Simphony TMS, Reservations, or Wait List with a loyalty application, you must configure the loadable loyalty module. Loyalty Configuration Tasks contains more information about configuring the loyalty module.
Related Topics
- Table Management
- Reservation List
- Wait List
- Table Management Configuration Levels
- Configuring Reservation Privileges
- Creating the Touchscreen Reservation List
- Setting Reservation Timing Parameters
- Reservation Configuration Levels
- Configuring Wait List Privileges
- Creating the Touchscreen Wait List
- Setting Wait List Timing Parameters
- Wait List Configuration Levels
Parent topic: Table Management
