PreviousNext
JavaScript must be enabled to correctly display this content
Configuring a Print Full Seat Check Service Total
Select the Enterprise or property, click Configuration, and then click Tender/Media.
Add a new record, and then double-click it to open in form
view.
Select 2 - Service Total from the Key Type drop-down list.
Click the Options tab, and then
click the Printing Options subtab.
Select 16 - Print Full Seat Check.
If you also select 14 - Print Seat Check, option 16 overrides option 14.
Select 21 - Print Summary Totals.
Click the Menu Levels tab, and
then select the Main and Sub Level on which the Print Full Seat Check
Service Total is available.
Click Save.
Add a touchscreen button for the tender/media record that
you created in Step 2. Creating
a Full Seat Check Button contains more information about configuring
the touchscreen button.
