Using Condiment Prefixes with Menu Item Classes Select the Enterprise, property, revenue center, or zone, click Configuration, and then click Menu Item Classes. Click the Options tab. For all regular menu item classes, select 65 - Support Enhanced Prefix Mode (Parent Only), and then click OK. If you are not using condiment prefixes, do not select 65 - Support Enhanced Prefix Mode (Parent Only). See Configuring Menu Item Classes and Assigning Condiments to Parent Menu Item Classes for more information. Click Save. Related Topics Condiment Prefixes Parent topic: Condiment Prefixes
