Assigning Default Condiments to Parent Menu Items
Default condiments are used for the following purposes:
The default building of a menu item (for example, a hamburger comes with tomato, onion, and pickle)
Breaking down a menu item to the ingredient level for inventory system integration (for example, the default number of pickles that accompany a hamburger)
Default condiments are not supported with Transaction Services. If you are using Transaction Services, workstation operators need to add default condiments separately.
Related Topics
