Select the Enterprise, property, or zone, click Configuration, and then click Discounts.
Double-click an automatic discount record to open it.
On the Auto tab, select 4 - Combination Pricing from the Automatic
(Automatically applied, operator cannot enter) drop-down
list.
(Optional) Enter a Priority for
the discount.
Priority determines the order in which discounts are calculated.
By default, this field is blank (0) for all discounts, meaning that
discounts are calculated at the same time. If you enter a priority,
the workstation calculates all discounts in priority 1, then in priority
2, and so on. Priority zero (0) discounts are calculated last. The
priority field allows Simphony to calculate discounts more efficiently.
If you are configuring an automatic coupon discount with
combination pricing, enter the maximum number of times the coupon
discount can be entered on a check in the Max Count Per
Check field. Enter a value of 0 to allow the discount to be added an unlimited amount of times to
the same check.
This field is active only for automatic discounts with the Activation Type of 2 - Coupon (Automatically
applied, operator must enter).
In the Trigger section, select up to eight unique Trigger MI Groups that invoke the discount. You must
configure the triggers in sequential order.
Enter the price to charge for this combo meal in the Amount Substitution field.
Enter the maximum number of combo meals that customers
can order per check in the Max Count field.
In general, the Max Count field is
set to 0 to allow an unlimited amount of combo
meals on a single check
