Configuring Menu Item Groups
- Select the Enterprise, property, or zone, click Configuration, and then click Menu Item Groups.
- Insert a menu item group record, and then double-click it to open.
- Click Add near one of the following
areas:
Include: You can add the menu item groups to include in the discount here
Exclude: You can add the menu item groups to exclude from the discount here
- Select information for the fields described in the following
table:
Table 15-10 Include and Exclude Fields
Field Description Type
Select the grouping to include or exclude:-
0 - None
1 - All
2 - By Major Group
3 - By Family Group
4 - By Menu Item
Start #
Click in this field, and then select the start item.
End #
Do not enter anything in this field.
See Items and Select
Click the link and then select the menu items to be the trigger. This item appears in the End # field.
Range
The items you selected in the See Items and Select dialog appear in this field.
Override Price Amount/Percentage (Include only)
If you want a discount to apply to menu items differently, use this field. For example, you can set discounts for Sweet Potato Fries to 15% and Pub Fries to 20%.
To use this field with automatic discounts, you must select the Use Price in MI Group Detail option from the Discounts module Auto subtab. You can set amount off, percent off, or amount substitution, based on the discount configuration. For example, enter 10.00 to indicate 10% off (not 0.10). The Use Price in MI Group Detail option does not function with combination pricing discounts.
- Click Save.
Parent topic: Menu Item Groups
