Select the Enterprise, zone, property, or revenue center,
click Setup, and then click PAR
Level Sets.
Insert a record, and enter the PAR Level Set name.
Double-click the record to open it.
Select the CM Class.
The CM Class list includes all Cash
Management classes that you created. These Cash Management classes
contain the units that are allowed within the PAR Level Set.
Add a Counting Unit using one of the following methods:
Select Add All Units to have ECM add
all defined units for the Cash Management class to the PAR Level.
Select Add Unit to manually add specific
units.
For each of the defined units, enter the quantity of units
to maintain as part of the PAR Level Set for each day of the week.
The Totals row beneath the Units table shows the cash value
required for each unit quantity and day of the week.
Click Save.
To edit a PAR Level Set, highlight the record, change the
values, and then click Save.
To delete a PAR Level Set, highlight the record, and then
select Delete.
You cannot delete a PAR Level Set that is associated with
one or more templates.
