A receptacle represents a physical or virtual location
used to store funds and draw transactions.
Select the Enterprise, zone, property, or revenue center,
click Setup, and then click Receptacles.
Insert a record, enter a unique name for the receptacle,
and then click OK.
Double-click the receptacle record to open it.
Enter or select information in the receptacle fields.
Receptacle Type: Select the type of
receptacle.
Template Name: Select the template to
use for this receptacle.
the receptacle is defined.
You can define a receptacle type
that is commonly used across an Enterprise or region without uniquely
defining it at each property or revenue center. The location allows
you to specify a receptacle name and configuration to be used in multiple
locations. When you select 2 - Property, a
receptacle is defined for each property based on the values entered.
When you select 3 - Revenue Center, a receptacle
is defined within each revenue center.
For
example, each property might have one safe to maintain all cash transactions
for the entire property. Create a safe receptacle from the Enterprise
level or zone, and then specify the property in the Location field. The safe receptacle is defined at all properties under the
selected level.
Options: Select Deactivate
Receptacle to prevent workstation operators from performing
further activity against the receptacle.
To edit a receptacle, highlight the record, change the
values, and then click Save.
To deactivate a receptacle, highlight the record, and then
select Deactivate Receptacle.
