PreviousNext
JavaScript must be enabled to correctly display this content
Configuring Tip Track Buttons
Select the Enterprise, property, revenue center, or zone,
click Configuration, and then click Page Design.
Open the page on which to place tip track buttons.
On the Edit tab, select the page
area in which to define the tip track functions.
Click Button.
On the General subtab, enter the
button name Tip Track Tip Out in the Legend field.
Select Function from the Type drop-down list.
Click the black arrow directly beneath the Type drop-down list, select Tips from the Type
section, select Tip Track Tip Out from the
Results section, and then click OK.
Repeat Steps 3 through 7 to create the following buttons:
