Assigning Logos and Colors to Pages
You can define a logo and color palette on Welcome pages. You can add only a logo to Hub pages because the color palette can be inherited from the Enterprise, property, or revenue center level based on the Theme Assignment module configuration.
Image files cannot exceed 1 MB in size. The following image file type formats are supported:
.bmp
.jpeg
.png
.gif
Copy logo images to the POS client device using a flash drive or download the images through the Internet.
- Open the page, and then tap anywhere within the grid.
- Select the color from the Palette drop-down list.
- To add a company logo to the page:
- Tap Open.
- Browse to the logo image file and select it. The directory path appears in the Logo field.
- Tap Save.
