Select the Enterprise, property, revenue center, or zone,
click Configuration, and then click Menu Item Maintenance.
Use the filters to search for the items to translate, and
then click Search.
To translate menu item master records, enter the translated
text in the relevant language column on the Master Records tab.
For example, to translate master records to Spanish, enter
the translated text in the Name - Spanish column.
Master records show a separate column for each language configured
in the Enterprise.
To translate menu item definitions, click the Definition Records tab, and then enter the translated
text in the relevant language column.
Definition records show two extra columns per language, First - [Language Name] and Second - [Language
Name], to allow translations for the first name and second
name of each definition.
