Printing a Secondary Language on Guest Checks and Customer Receipts
To configure Simphony to print menu items in an alternate language beneath the default language on guest checks and customer receipts:
  1. Select the property, click Setup, and then click Property Parameters.
  2. On the General tab, select a language from the Select Secondary Print Language drop-down list. Select 0 - None to print only the default language.
  3. Click Save.
  4. Select the Enterprise, property, revenue center, or zone, click Setup, and then click Format Parameters.
  5. Click the Options tab.
  6. Select 52 - Print Secondary Language on Guest Checks/Customer Receipt.
  7. Click Save.
