Allowing Users to Override Restricted Menu Item Ranges
You can allow users to add, edit, and delete menu item master records, definitions, and prices for menu item object numbers that are set as restricted in the Properties module.
- Select the Enterprise level, click Configuration, and then click Roles.
- Double-click an employee role.
- Click the EMC Modules tab.
- From the Menu Items section, select the Edit privilege option for Menu Item Master Restriction.
- Click Save.
Related Topics
Parent topic: Menu Item Definitions
