Configuring Active Menu Levels for Menu Item Definitions and
Prices
Prices
Select the Enterprise, property, revenue center, or zone,
click Configuration, and then click Menu Item Maintenance.
Search for and then double-click a menu item master record.
If the menu item has multiple definitions, select a definition,
and then click the General tab.
From the Menu Level Availability section, select the active
main and sub levels for the item.
To set the menu item definition as active on all menu levels,
click All.
To set the menu item definition as active on a custom menu
level:
Click Menu Levels Tab, select
a Menu Level Set, and then select the menu
levels.
To set the definition as active on all custom levels,
select Active on All Levels.
If the menu item has multiple price records click Prices, and then select the Active Menu Level for each price definition.
When menu items are assigned to a class which uses sub level
pricing (Menu Item Class option 10 - ON = Use Sub Level
Pricing; OFF = Use Main Level Pricing is set), Simphony
lists sub levels.
