PreviousNext
JavaScript must be enabled to correctly display this content
Configuring Auto Menu Levels
Select the Enterprise, property, revenue center, or zone, click Configuration, and then click Auto Menu Levels.
In the Start column, enter the time at which the menu level becomes active.
In the End column, enter the time at which the menu level becomes inactive.
Select the Main Level, and then select the Sub Level.
Click the ellipsis point (...) button from the Options column.
Select 1 - This Entry is Active, and then select one or more of the following options that correspond with the days that the menu level becomes active:
