Configuring Master Records for Menu Items
You can add master records for menu items, along with menu item definitions and prices, using a template record. If you are creating a new property and there are no template records to use, at first you can add only a menu item master record, and then add menu item definition and price records later.
If a menu item name includes the special characters, $#$, they are replaced with the object number of the record being created. For example, if the name is My Record $#$ and is being inserted into object number 4, the new record is created as My Record 4.
