Searching and Filtering Menu Items
The Menu Item Maintenance module allows you to search for menu items. Typically several thousand menu item records are likely to exist. Searching and filtering allows you to work with only the desired menu item records. By default, no items appear in table view.
Parent topic: Enterprise Management Console
