Configuring Order Types as Subtotal Keys
You can allow the Order Type keys in the revenue center to act as Subtotal keys. After pressing the Order Type key, the items ordered are considered previous-round items for voiding purposes. This is a security option to prevent fast transaction operators from voiding items after viewing the check subtotal.
- Select the Enterprise, property, or revenue center, click Setup, and then click Control Parameters.
- Click the Options tab.
- If you do not want summary totals (subtotal, tax, amount due, and change due) to appear on the workstation until the workstation operator presses an Order Type key, select 8 - Display Summary Totals Only After Order Type Declared.
- Click Save.
