PreviousNext
JavaScript must be enabled to correctly display this content
Creating, Editing, and Removing Printer Groups
Select the property, click Setup, and then click Printer Groups.
Insert a printer group record, name the printer group,
and then click OK.
Double-click the printer group record to open it.
To add a printer to the printer group, click the Add link, click the ellipsis button, and then select
the printer.
You can add any printer to any printer group, regardless
of the Destination Printer option setting.
You can add one printer to multiple printer groups.
Repeat Steps 1 through 4 for to create more printer groups
and to add printers to the groups.
To delete a printer from a printer group, select the printer,
and then click the Delete link.
Click Save.
To edit a printer group, highlight the record, change the
values, and then click Save.
To remove a printer group, highlight the record, and then
click Delete on the toolbar.
