Configuring an Alpha-Numeric Keyboard
The following steps describe how to configure an Alpha-Numeric
Keyboard in EMC:
- In Enterprise Management Console, select the property, click the Setup tab, and then click Alpha-Numeric Keyboard under the Custom Content section.
- Insert a new record. Choose Regular Alpha-Numeric or Small Screen Alpha-Numeric from the template record drop down menu.
- Add a name for the record, and then click OK.
- In the list view, set the desired language from the Language drop down menu.
- Click the Options button, and then ensure that the Default keyboard for this language option is enabled.
- Double-click the record to enter page design view.
- In page design, add the necessary buttons for the workstation. Ensure that the Popup Alpha Numeric Keyboard button is added. In addition to this, add a Cancel button to be able to exit in the workstation.
- Click the Save icon to complete.
