Allowing Employees to Run Reports
- Select the Enterprise level, click Configuration, and then click Roles.
- Select the role type, click the Operations tab, and then click the PMC General/Reports sub-tab.
- Select 30001 - Run PMC to allow employees associated with the role to launch the Property Management Console (PMC) on the workstation using Function Key 300, Launch PMC.
- Click the Ad Hoc Reports tab.
- From the Report Options section, select the reports you want employees to run.
- Click Save.
Related Topics
Parent topic: Reporting
