PreviousNext
JavaScript must be enabled to correctly display this content
Configuring Effectivity for Table Management Reservations
Select the revenue center, click Setup, and then click Reservation Periods.
Insert a record with a name that describes the reservation
period (for example, Weekday or Weekend).
Double-click the record to open it.
On the Effectivity tab, select the
appropriate options as described in the following table:
Table 43-16 Effectivity
Option
Description
Effectivity Start Date
Select the first calendar day that the reservation period
is effective. Deselecting the start date causes the reservation period
for the reservation and wait lists to remain in effect indefinitely.
Effectivity End Date
Select the last calendar day that the reservation period
is effective. Deselecting the end date causes the reservation period
Recurrence Day Of Week
Select the effective days of the week within the reservation
period. You must select at least one day in order to save the reservation
period.
Recurrence Time Of Day
Select the time of day that is effective in the reservation
period.
Deselecting the Active Start Time causes the reservation period for the reservation and wait lists
to remain in effect starting at 00:00:00 on the applicable calendar
days.
Deselecting the Active End Time causes the reservation period for the reservation and wait lists
to remain in effect until 23:59:59 on the applicable calendar days.
