Configuring Surcharges
- Create a surcharge tax rate:
- Select the Enterprise, property, or zone, click Setup, and then click Tax Rates.
- Insert a record and name it for the surcharge.
- Select the 4 - Surcharge tax rate type from the Type drop-down list.
- Click Save.
- Create a surcharge tax class:
- Select the Enterprise, property, or zone, click Setup, and then click Tax Classes.
- Insert a tax class record and name it for the surcharge.
- From the Taxes Enabled field, select the surcharge tax rate, and then click OK.
- Click Save.
- Configure the Tax Mask:
- Select the Enterprise, property, revenue center, or zone, click Setup, and then click Order Type Parameters.
- Click the ellipsis point (...) button in the Tax Mask column, select the surcharge tax rate for the order type, and then click OK.
- Ensure that Active is enabled for the order type with the surcharge tax rate.
- Click Save.
- Configure the serving period for the tax rate:
- Select the revenue center, click Configuration, and then click Serving Periods.
- Insert a record and enter the serving period name, or select an existing serving period.
- On the Taxes tab, select the surcharge tax rate
- Click Save.
- Change the Menu Item Class to the surcharge tax class:
- Select the Enterprise, property, revenue center, or zone, click Configuration, and then click Menu Item Classes.
- Double-click the menu item class.
- On the General tab, select the surcharge tax class from the Tax Class drop-down list.
- Click Save.
- Configure the surcharge for the Menu Item Definition record:
- Select the Enterprise, property, revenue center, or zone, click Configuration, and then click Menu Item Maintenance.
- Double-click the menu item master record corresponding to the definition to open it.
- Click the General tab, and then enter the surcharge for the menu item in the Surcharge field.
- Click Save.
Parent topic: Surcharges
