Configuring the Host Command Area
  1. Select the Enterprise, property, or revenue center, click Configuration, and then click Page Design.
  2. Double-click the page on which to define the Host Command Area.
  3. On the Edit tab, select the page area on which to place the Host Command Area. You must place the Host Command Area in the same content area on the page as the tables in order for the host features to function.
  4. Click Other..., select Table Management, and then select Host Command Area.
    Hosting staff performs a long button press on the Host Command Area to access the TMS functions. As such, carefully consider the Host Command Area sizing and placement to ensure that hosting staff can easily see and press this area on the POS client.
    The Host Command Area can optionally show an image in place of the silver portion of the area. You can set the image from the TMS Parameters module as the Dining Table Decoration Image Name. The image you select scales to the size of the Host Command Area.
  5. Click Save.
