Givex Host Adaptor
Due to the Givex Processor requiring communication with a vendor host adaptor (which in turn communicates with the vendor's host system using a vendor-specific protocol), you need to download and install the host adaptor to a workstation.
Givex is Windows-based, and as such, runs as a Windows service on workstations.
For more information on how to download and install Givex to a workstation, contact your Givex representative for assistance.
The Givex Host Adaptor has its own configuration file called GIVEX.INI, which requires modification in the following areas:
  • Connection information for the Givex host.
  • Record numbers to map to Givex Transactions, specifically:
    • INVENTORY_BASE relates 4 transactions to Service Charge entries.
    • TENDER_BASE relates 6 transactions to Tender/Media.
After modifying the configuration file, restart the Givex Host Adaptor service. The name of the service is Givex SVC Adaptor.
For more detailed information on how to configure the Givex Host Adaptor, see Configuring the Givex Host Adaptor.
