Send Service Host Download Packages to All Devices
Sign in to EMC.
Click the Enterprise, Setup tab,
and then CAL Packages.
Select All from the CAL packages
tree.
Click the Deployment Schedules tab.
Click the Add Deployment link.
Click the down arrow under Choose CAL Packages
to upload to access the drop-down list, select Service Host Download x.x.x, and then select [file name]
for the version of Simphony you are upgrading to. The (xxx) refers
to the version number.
Figure 1-5 CAL Packages Add Service Host Download Deployment
With the Deployment Type set to
the default setting of 1 - Property/Enterprise, click the ellipsis ‘…’ adjacent to the drop-down
list.
Select your property from the list, and then click OK to close the Select Properties list. Click OK again to close the CAL package selection window.
Figure 1-6 CAL Packages Service Host Select Properties Window
(Optional) If you want to schedule the download of Service
Host packages, configure the Effective From and Effective To date columns.
Verify the Action to Take column
shows Install, and then click Save.
Your workstations should begin receiving the Service Host
updates (or at the scheduled time).
Workstations restart multiple times while
upgrading. Allow the upgrade to run uninterrupted until completed.
If you see a failed message during the deployment,
stop and troubleshoot immediately.
