Click the Enterprise, Setup tab,
and then CAL Packages.
Select All from the CAL packages
tree.
Click the Deployment Schedules tab.
Click the Add Deployment option.
Click the down arrow under Choose CAL Packages
to upload to access the drop-down list, select CAL Client.x.x.x, and then select [file name] for the
version of Simphony you are upgrading to. The (xxx) refers to the
version number.
Set the Deployment Type to 2 - Specific Service Host from the drop-down list, and
then click the ellipsis ‘…’ adjacent to the Deployment Type drop-down list.
Select the Check and Posting Service (CAPS) workstation for your property, and then click OK to close the Select Specific Service Host list. Click OK again to close the CAL package selection window.
Figure 1-7 CAL Packages Add Deployment for a Specific Service Host for
CAPS Workstations
Verify the Action to Take column
shows Install, and then click Save.
Your CAPS workstation should begin receiving the CAL Client
updates (or at the scheduled time).
The CAPS workstation restarts multiple times while
upgrading. Allow the upgrade to run uninterrupted until completed.
If you see a failed message during the deployment,
stop and troubleshoot immediately. If you see a message showing Local Db Max Size, press OK. You
can ignore this message for now, but it is recommended you check the
free space on the hard drive of the CAPS workstation after the upgrade
is complete.
