Interface Ports
All TCP ports used for Simphony interfaces are configurable from within the interface configuration of EMC. The following are the default TCP ports for common interfaces:
Table 4-3 Default Interface Port Numbers
| Interface | Port Number | Configurable? |
| Table Management System | 5006 | Yes |
| Property Management System | 5007 | Yes |
| Credit Authorization | 5008 | Yes |
| System Interface Module (SIM) | 5009 | Yes |
Parent topic: Port Numbers
