Property Ports
Starting with Simphony 19.6, a Secure Port column is now available from the Simphony EMC modules listed below. ServiceHosts now listen on separate HTTP and HTTPS ports for peer communications.
Access the EMC and then navigate to each module by selecting the following:
                     Location, Setup, Property Parameters, Workstations tab
                     Location, Setup, Workstations, Service Host tab
                     Location, Setup, KDS Controllers, Service Host tab
                     Location, Setup, KDS Controllers, Backup Service Host tab
                     Enterprise, Setup, Service Hosts module
                     Enterprise, Setup, Interfaces module
The Secure Port number column is non-configurable by design. You should expect (and allow) increased network traffic from any ServiceHosts assigned to these secure ports.
Table 4-2 Property Ports
| Service | Port Number | Configurable? |
| ServiceHost version 2 | HTTP: 8080 HTTPS: 8087 | Only HTTP is configurable |
| ServiceHost as a Service (no Ops) | HTTP: 8071 HTTPS: 8087 | Only HTTP is configurable |
| Print Controller | HTTP: 8080 HTTPS: 8087 | Only HTTP is configurable |
| IP Printer Listening | HTTP: 9100 | Yes |
| Banquet Printing | HTTP: 9100 | Yes |
| KDS Client (Display) | HTTP: 5022 | Yes |
| KDS Controller Service | HTTP: 5023 | Yes |
| KDS Backup Controller Service | HTTP: 5031 | Yes |
| Client Application Loader (server selection screen) | TCP 7300 | No |
| Client Application Loader (property selection screen) | HTTP: 8080 | Yes |
| NetTCPRelayBinding (TMS/Azure) | TCP: 9350, 9351, 9352 | No |
| NetTCPRelayBinding (TMS/Azure) | HTTP: 80 | No |
Workstations running Oracle Linux for MICROS are preconfigured with firewall rules, and available ports are limited. If this feature is needed, then the firewall rules must be manually adjusted.Parent topic: Port Numbers
