Changing the Seat Number of Menu Items on a Check
When a check is filtered by seats, Simphony only allows you to assign menu items to a seat number that is in the filtered list. For example, if a check is filtered by seat 1, seat 2, and seat 3 and you want to change the seat number of items belonging to seat 3, you can only change it to either seat 1 or seat 2.
- Select the menu items that belong to the seat you want to modify, and then press Edit Seat.
- Enter the new seat number, and then press OK.
Related Topics
Parent topic: Guest Checks
