Filtering a Check by Seat Number
- Pick up a check that has menu items from multiple seats.
- To filter a single seat, use one of the following methods:
- Press Add Seat to Filter, enter the seat number, and then press OK.
- Press the seat number using the on-screen numeric key pad, and then press Add Seat to Filter.
- To filter multiple seats:
- To clear the seat filter, press Clear Seat Filter.
Related Topics
Parent topic: Guest Checks
