Adding Suites Owner Information to a Check
- Press the Add Check to Suite function key, enter the suite number, and then press OK.
- Enter the suite guest name, and then press OK.
- Enter the number of the check to add guest information, and then press OK.
- Select the suite guest name that you entered in Step 2 from the suites owner list, and then press OK.
- Make the necessary changes, and then end the current service round of the Suites check.
Parent topic: Guest Checks
