Applying a Menu Item Tax Class Override
The Menu Item Tax Class Override allows you to modify the tax rate applied to a certain group of menu items. This modification of the tax rate is predicated on a quantity threshold, and if the threshold value is met or exceeded, the tax class override will be applied to the tax rate of an item or items.
To apply a menu item tax class override:
Parent topic: Guest Checks
