Declaring Waste
- Click the Declare Waste function key.
- Enter the menu item. If more than one of the same item is wasted, select the quantity, and then select the menu item to add to the waste check.
- Select a waste reason, and then click OK.
- Repeat Steps 2 and 3 to add menu items to the waste check.
- Perform a service total on the check. A waste receipt prints and the workstation closes the waste check.
Related Topics
Parent topic: Menu Items
