Seating a Guest Using Quick Seat
You can rapidly seat a guest using the Quick Seat feature without adding them to the Wait List.
  1. While there are no records selected on the Wait List, use one of the following methods to start the Quick Seat process:
    • Double-tap the table.
    • Long-press the table and select Quick Seat.
    See Enhanced Table Status and Functions for more information on the Quick Seat function and how the function operates when you use the long-press method.
  2. Change the Cover Count on the Quick Seat dialog by entering a new number, or using the + and buttons, and then clicking OK.
    • If you attempt to quick seat a guest with covers below or above the minimum or maximum table capacity, the application prompts you to confirm.
    • If you attempt to quick seat a guest at a table that does not meet the system requirements (for example, the table is unavailable or unassigned), the application prompts you for authorization if you do not have the appropriate privilege.
  3. Click Yes to begin a new guest check.
Related Topics
