Allowing Employees to Install and Authenticate POS Clients and Service Hosts
Beginning with Simphony release 19.3 and later, you must allow administrator employees to download software, install, and authenticate clients and service hosts using CAL version 150 or later. After granting this privilege, employees can use their credentials to configure POS clients. In addition, the User Security Credentials configured in the Property Parameters module become inactive.
  1. Select the Enterprise, click Configuration, and then click Roles.
  2. Double-click an employee role.
  3. Click the Operations tab, click the Miscellaneous subtab , and then select 10065 - Download Software, Install and Authenticate Clients and Service Hosts Using CAL.
  4. Click Save.
