2 Enterprise Management Console
Administrators can configure Simphony using the Enterprise Management Console (EMC) tool. This application allows you to set up the Enterprise, properties, revenue centers, and zones from a computer which has access to the central server.
- Overview
- Device Information
- Accessibility Settings
- Adjust Display Scaling
- Distribution
- Searching and Filtering Menu Items
- Configuring Permissions
- Privacy and Personal Data Management
- Setting the Max Allowed Failed Logins for EMC Access
- Configuring the SMTP and Backup SMTP Servers in the EMC
- Configuring Workstation Database Passwords
