39 Importing and Exporting Data
Import and export Simphony application data in a comma-separated values (CSV) format, to or from spreadsheet applications
Import configuration data into the Simphony application database that can be called by external systems, such as a web service application programming interface (API)
Export configuration data from Simphony that can be called by external systems, such as an on premise inventory management application
Allows you to load configuration data in bulk (for example, making a large number of price changes for menu items, which reduces the amount of time it takes to configure systems)
Allows third parties to integrate with customer databases (either self-hosted or hosted within an Oracle facility), without providing direct access to the application file server or database
Allows third parties to build custom interfaces
See the Oracle Simphony Manager User Guide for more information about importing and exporting data.
