Configuring Touchscreen Buttons for Order Channels
You need to configure buttons that workstation operators can use for order channel functions on the workstation.
Table 14-2 Touchscreen Buttons for Order Channels
| Button | Description |
Order Channel |
Set or change the order channel for a check.
Pickup Check by Order Channel |
Pick up open checks by order channel on the workstation.
Parent topic: Order Channels
