Printer DIP Switch/Memory Switch Setting when using UB-IDN (IDN02) Interface
Table 32-12 TM-U200, TM-U220, TM-U2300
| DIP | SW | 1 | DIP | SW | 2 | ||||||||||
| 1–1 | 1–2 | 1–3 | 1–4 | 1–5 | 1–6 | 1–7 | 1–8 | 2–1 | 2–2 | 2–3 | 2–4 | 2–5 | 2–6 | 2–7 | 2–8 |
| x | x | OFF | OFF | OFF | OFF | OFF | x | ON* | x | x | x | x | x | x | x |
Table 32-13 TM-T88 Series
| x | x | OFF | OFF | OFF | OFF | ON | OFF | x | x | x | x | x | x | x | x |
Table 32-14 TM-T90, TM-L90 (Non-Peeler & Peeler)
| DIP | SW | 1 | |||||
| x | ON | OFF | OFF | OFF | OFF | ON | OFF |
Table 32-15 TM-T70
Table 32-16 TM-T70II
| No DIP SW or Memory SW change is necessary. |
| Use GS (E command (Fn=11)) to set Serial Port Communication Parameters. |
Table 32-17 Legend
| OFF | ON | = Mandatory Setting |
| OFF* | ON* | = Recommended Setting |
| x | = Don’t Care |
Parent topic: Printer DIP and Memory Switch Settings
