Menu Item Images
If configured, a menu item image may also be displayed on the information
screen. To enable this, enter @INFO in the Comments field for the menu item definition image. If
this field is not configured, no image is displayed.
If Simphony Transaction Services Generation 2 is used for images and image comments, a different image slot can be used for the allergen image. The maximum size for an image is 1 KB.Figure 17-33 Menu Item Definition Images Tab
See Configuring Menu Item Definitions, Family Groups, and Condiment Group Names Consumer-Facing Settings for configuration instructions.
Parent topic: Extension Application Plug-in for Menu Item Information
