Prerequisites
The following table lists the prerequisites for the Menu Item Information plug-in.
Table 17-19 Menu Item Information Plug-in Prerequisites
Compatibility |
The solution is used with Simphony release 19.4 and later. This application is available for Simphony workstations running the Microsoft Windows or Oracle Linux for MICROS operating systems. This plug-in is not supported on Android, macOS, or other operating systems. |
Setup |
Configuration of all Simphony settings, including Page Design and nutritional and allergen information, is a manual process. Specific instructions regarding design elements are not included in this document. The administrator of this solution must design and configure screens and buttons based on location and cosmetic preferences. |
Parent topic: Extension Application Plug-in for Menu Item Information
