Insert Content: Simphony_MenuItemInformation
Highlight the new record, and then click Insert Application Content.
Enter the following information in the Insert System Template dialog, and then click OK. The value entered for ZoneableKey is case sensitive and must be entered exactly as shown.
Zoneable Key: Simphony_MenuItemInformation
Description: Application
Figure 17-25 Insert System Template Dialog
In the Content Type field, select 3 - DLL, and then click Import from a file.
Figure 17-26 Content Type Field
Navigate to the fileSimphony_MenuItemInformation.dll, select the file, and then click Open.
Click General, and then enter
Simphony_MenuItemInformation.dllin the Disk File Name field. The value entered for Disk File Name is case sensitive and must be entered exactly as shown.Figure 17-27 Disk File Name Field
Scroll to the right, click Target, select 1 - Win32 and 14 - Linux only, and then click OK. Do not enable options for Version: (any) - (any).
Figure 17-28 Target Dialog
Click Save.
Parent topic: Extension Application Installation
