Check Numbers
A guest check number can be between 1 and 99999999 (an eight-digit number). Typically check numbers are created in sequential order. If a workstation operator begins check number 10000007, the next check number for the revenue center is 10000008. Check numbers are maintained at the revenue center.
If a location has multiple revenue centers and wants to keep unique check numbers for each revenue center, you can assign an exclusive range of check numbers per revenue center. For example, Revenue Center 1 could have checks from 1000 to 1999 and Revenue Center 2 could have checks from 2000 to 2999.
